Provisioning Linksys 942
Discussion in '3CX Phone System - General' started by Spyklee, Oct 1, 2008.
  1. Spyklee
    Nov 1, 2007
    45
    I've configured one of our Linksys devices according to http://www.3cx.com/sip-phones/linksys-spa-9xx-provision.html
    But I don't see any automatic updates? I assume if the name (user) of the extension has changed in the PABX this should be updated by the provisioning to the phone?
    Are there any debug options?
    Cheers!
    Eric
  2. Resolve
    Sep 19, 2007
    94
    Hi Eric,
    If you edit the <macID of linksys>XML file generated on the server - remove the $MA and replace it with the phones' mac address, you should be ok. It seems the replacement of $MA with the phone's mac address just isn't happening.....
    Tim
