Provisioning phones
Discussion in '3CX Phone System - General' started by Parhunter, Mar 30, 2018.
Tags:
  1. Parhunter
    Jul 21, 2017
    I have noticed when I hang a brand new phone on my network it shows up in bold text as un-provisioned under my phones tab. If I provision the phone everything works as advertised. But then something happens to the user or phone and I need to provision them a new phone.. No problem there either, but if I factory reset the first phone and put it back on the network it doesn't show up. Is the system storing the MAC address and not displaying it again? Is there someplace I can tell the PBX to release the phone's MAC address?
    I'm using Yealink phones T23Gs and T46Ss. Any help would be appreciated.
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    692
    99
    Try deleting the phone from the provisioning tab on the ext. select the correct phone and click delete
  3. Parhunter
    Jul 21, 2017
    I did that. Still nothing, but like I said a new one out of the box shows right up?
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    3,474
    239
    Hello @Parhunter
    If the PBX is able to receive multicast messages then the phones should be displayed if they are factory provisioned. There is nothing in the PBX to prevent this so phones that are already provisioned should appear. Make sure that the phones do not retain any settings and that they are indeed factory reset. You may also need to run a wireshark capture and see if the phone is sending a multicast message as it boots up.
