Provisioning Question for non-standard phones
Discussion in '3CX Phone System - General' started by ehcah, Nov 28, 2011.
  1. ehcah
    Nov 28, 2011
    I currently have several Cisco IP 7975G's running SIP 75.8-3-2SR1S. They are all under support and I can upgrade/downgrade to any necessary firmware version required that will work best with 3CX 10 SP4. Under a different platform the above mentioned firmware version seemed to work best. This does not seem to be the case within 3CX.
    Where I am new to a Windows GUI approach, but not the xml's. I have a few questions from provisioning, to the format of the files themselves. I can certainly appreciate and do apologize in advance for the redundancy in some of these questions. I know they get asked often and simply reworded. I have searched infinity and beyond on the 7975 and they seem to be a hit and miss model to get working.
    First off... When you are not dealing with a Linksys or Cisco SPA series phone. Do you still provision the phone through 3CX or simply prep the xml config for the phone ie.. SEPABCDEF123456.cnf.xml and upload the files via a 3rd party TFTP server etc... Either way, I have not found way a way to create a custom provisioning file for this phone and upload it through 3CX. My standalone configuration does not seem to allow standard features like call waiting, 3 way calling or call forward to work. The keys are there on the phone, but do not function. I can however, successfully register with my SIP Trunking Voip Provider and have multiple live phone lines on the phone. I can also make and receive 1 phone call at a time. As mentioned, call waiting rings my softphone client, but not my desktop. My out of province DID's which make up other Line's 1-5, all ring on Line 1?
    Here is a copy of my file SEPABCDEF123456.cnf.xml
    <device xsi:type="axl:XIPPhone" ctiid="1234567891">
    <deviceProtocol>SIP</deviceProtocol>
    <sshUserId>xxxxxx</sshUserId>
    <sshPassword>xxxxxx</sshPassword>
    <devicePool>
    <dateTimeSetting>
    <dateTemplate>M/D/Ya</dateTemplate>
    <timeZone>Atlantic Standard/Daylight Time</timeZone>
    <ntps>
    <ntp>
    <name>192.43.244.18</name>
    <ntpMode>directedbroadcast</ntpMode>
    </ntp>
    </ntps>
    </dateTimeSetting>
    <callManagerGroup>
    <members>
    <member priority="0">
    <callManager>
    <ports>
    <ethernetPhonePort>2000</ethernetPhonePort>
    <sipPort>5060</sipPort>
    <securedSipPort>5061</securedSipPort>
    </ports>
    <processNodeName>10.10.1.8</processNodeName>
    </callManager>
    </member>
    </members>
    </callManagerGroup>
    </devicePool>
    <sipProfile>
    <sipProxies>
    <backupProxy></backupProxy>
    <backupProxyPort></backupProxyPort>
    <emergencyProxy></emergencyProxy>
    <emergencyProxyPort></emergencyProxyPort>
    <outboundProxy></outboundProxy>
    <outboundProxyPort></outboundProxyPort>
    <registerWithProxy>true</registerWithProxy>
    </sipProxies>
    <sipCallFeatures>
    <cnfJoinEnabled>true</cnfJoinEnabled>
    <callForwardURI>x--serviceuri-cfwdall</callForwardURI>
    <callPickupURI>x-cisco-serviceuri-pickup</callPickupURI>
    <callPickupListURI>x-cisco-serviceuri-opickup</callPickupListURI>
    <callPickupGroupURI>x-cisco-serviceuri-gpickup</callPickupGroupURI>
    <meetMeServiceURI>x-cisco-serviceuri-meetme</meetMeServiceURI>
    <abbreviatedDialURI>x-cisco-serviceuri-abbrdial</abbreviatedDialURI>
    <rfc2543Hold>false</rfc2543Hold>
    <callHoldRingback>2</callHoldRingback>
    <localCfwdEnable>true</localCfwdEnable>
    <semiAttendedTransfer>true</semiAttendedTransfer>
    <anonymousCallBlock>2</anonymousCallBlock>
    <callerIdBlocking>2</callerIdBlocking>
    <dndControl>0</dndControl>
    <remoteCcEnable>true</remoteCcEnable>
    </sipCallFeatures>
    <sipStack>
    <sipInviteRetx>6</sipInviteRetx>
    <sipRetx>10</sipRetx>
    <timerInviteExpires>180</timerInviteExpires>
    <timerRegisterExpires>1200</timerRegisterExpires>
    <timerRegisterDelta>5</timerRegisterDelta>
    <timerKeepAliveExpires>120</timerKeepAliveExpires>
    <timerSubscribeExpires>120</timerSubscribeExpires>
    <timerSubscribeDelta>5</timerSubscribeDelta>
    <timerT1>500</timerT1>
    <timerT2>4000</timerT2>
    <maxRedirects>70</maxRedirects>
    <remotePartyID>false</remotePartyID>
    <userInfo>None</userInfo>
    </sipStack>
    <autoAnswerTimer>1</autoAnswerTimer>
    <autoAnswerAltBehavior>false</autoAnswerAltBehavior>
    <autoAnswerOverride>true</autoAnswerOverride>
    <transferOnhookEnabled>false</transferOnhookEnabled>
    <enableVad>false</enableVad>
    <preferredCodec>g711ulaw</preferredCodec>
    <dtmfAvtPayload>101</dtmfAvtPayload>
    <dtmfDbLevel>3</dtmfDbLevel>
    <dtmfOutofBand>avt</dtmfOutofBand>
    <alwaysUsePrimeLine>false</alwaysUsePrimeLine>
    <alwaysUsePrimeLineVoiceMail>false</alwaysUsePrimeLineVoiceMail>
    <kpml>3</kpml>
    <natEnabled>false</natEnabled>
    <natAddress></natAddress>
    <phoneLabel>"My Name"</phoneLabel>
    <stutterMsgWaiting>1</stutterMsgWaiting>
    <callStats>false</callStats>
    <silentPeriodBetweenCallWaitingBursts>10</silentPeriodBetweenCallWaitingBursts>
    <disableLocalSpeedDialConfig>false</disableLocalSpeedDialConfig>
    <startMediaPort>16384</startMediaPort>
    <stopMediaPort>32766</stopMediaPort>
    <sipLines>
    <line
    button="1">
    <featureID>9</featureID>
    <featureLabel>(xxx) xxx-xxxx</featureLabel>
    <proxy>USECALLMANAGER</proxy>
    <port>5060</port>
    <name>201</name>
    <displayName>201</displayName>
    <autoAnswer>
    <autoAnswerEnabled>2</autoAnswerEnabled>
    </autoAnswer>
    <callWaiting>3</callWaiting>
    <authName>201</authName>
    <authPassword>xxxxx</authPassword>
    <sharedLine>false</sharedLine>
    <messageWaitingLampPolicy>1</messageWaitingLampPolicy>
    <messagesNumber>*99</messagesNumber>
    <ringSettingIdle>4</ringSettingIdle>
    <ringSettingActive>5</ringSettingActive>
    <contact>201</contact>
    <forwardCallInfoDisplay>
    <callerName>true</callerName>
    <callerNumber>false</callerNumber>
    <redirectedNumber>false</redirectedNumber>
    <dialedNumber>true</dialedNumber>
    </forwardCallInfoDisplay>
    </line>
    <line
    button="2">
    <port>5060</port>
    <name>202</name>
    <displayName>202</displayName>
    <autoAnswer>
    </autoAnswer>
    <callWaiting>1</callWaiting>
    <authName>202</authName>
    <authPassword>xxxxxx</authPassword>
    <contact>202</contact>
    </line>
    </sipLines>
    <voipControlPort>5060</voipControlPort>
    <dscpForAudio>184</dscpForAudio>
    <ringSettingBusyStationPolicy>0</ringSettingBusyStationPolicy>
    <dialTemplate>dialplan.xml</dialTemplate>
    </sipProfile>
    <commonProfile>
    <phonePassword></phonePassword>
    <backgroundImageAccess>true</backgroundImageAccess>
    <callLogBlfEnabled>2</callLogBlfEnabled>
    </commonProfile>
    <loadInformation>SIP75.8-3-2SR1S</loadInformation>
    <vendorConfig>
    <disableSpeaker>false</disableSpeaker>
    <disableSpeakerAndHeadset>false</disableSpeakerAndHeadset>
    <pcPort>0</pcPort>
    <settingsAccess>1</settingsAccess>
    <garp>0</garp>
    <voiceVlanAccess>0</voiceVlanAccess>
    <videoCapability>0</videoCapability>
    <autoSelectLineEnable>0</autoSelectLineEnable>
    <webAccess>0</webAccess>
    <spanToPCPort>0</spanToPCPort>
    <loggingDisplay>1</loggingDisplay>
    <loadServer></loadServer>
    <headsetWidebandUIControl>0</headsetWidebandUIControl>
    <headsetWidebandEnable>0</headsetWidebandEnable>
    </vendorConfig>
    <versionStamp></versionStamp>
    <userLocale>
    <name>English_United_States</name>
    <uid>1</uid>
    <langCode>en_US</langCode>
    <version>1.0.0.0-1</version>
    <winCharSet>iso-8859-1</winCharSet>
    </userLocale>
    <deviceSecurityMode>1</deviceSecurityMode>
    <authenticationURL></authenticationURL>
    <directoryURL>http://10.10.1.8/xmlservices/PhoneDirectory.php</directoryURL>
    <idleURL></idleURL>
    <informationURL></informationURL>
    <messagesURL></messagesURL>
    <proxyServerURL></proxyServerURL>
    <servicesURL>http://10.10.1.8/xmlservices/index.php</servicesURL>
    <dscpForSCCPPhoneConfig>96</dscpForSCCPPhoneConfig>
    <dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>
    <dscpForCm2Dvce>96</dscpForCm2Dvce>
    <capfAuthMode>0</capfAuthMode>
    <capfList>
    <capf>
    <phonePort>3804</phonePort>
    </capf>
    </capfList>
    <certHash></certHash>
    <encrConfig>false</encrConfig>
    </device>
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    The 7975's are not supported on third party PBX's from Cisco therefor 3CX does not provide support for them. Try reading this article and see if it helps:
    http://www.888voip.com/configuring-cisco-7975-ip-phones-for-sip/
