Provisioning "Remote Ring tone Control" in Snom M300/M700
Discussion in 'Ideas' started by Bastien Flament, Jan 14, 2019.
  1. Bastien Flament
    Dec 3, 2018
    9
    Dear,
    We had the issue than even with only one ringtone set on our Snom M25/M65 there was a distinctive ringtone for calls made on a DID which had the default ringtone (i.e. Melody 1).
    As seen with the 3CX support this is an option in the server menu of the M300/M700 which is to disable (or leave it as it is for the distinction) -> "Remote Ring Tone Control".
    That could be useful (but not necessary) to be able to provision it from the FXS/DECT menu.
    Thanks,
    Bastien
