Provisioning Security
Discussion in '3CX Phone System - General' started by jtrollen, Sep 17, 2010.
  1. jtrollen
    May 17, 2010
    21
    I'm in the process of installing and provisioning a handful of phones and it occurred to me that this could be a huge security hole. In theory, I could look on the bottom of a phone to get the MAC address and pull up the provisioning XML file in a web browser with all of the users information. I could then log in as another user if I wanted to. Am I missing something here? This just seems too easy. How are people securing the provisioning XML files?
    Thanks,
    -John
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    We only allow access to the provisioning area for known IP addresses as source requestor.
    I have never tried (but will test it soon now you mention it) putting the config on a non standard port also, which should help.
    I dont see any other way that you can secure it to the outside world yet still let phones pick up configuration.
