Provisioning SNOM870 with V14SP2 did not function - can not registry an server
Discussion in '3CX Phone System - General' started by max999, Jan 11, 2016.
  1. max999
    Jan 10, 2016
    11
    - we installed V14SP2
    - we make a Phone Provisioning (screenshot attached)
    - we make a Firmware update on the SNOM phone to the latest level: 8.7.5.35
    - we entered the URL from the 3CX "System Status page" to the SNOM web menü (scrreenshot attached)
    - the SNOM phone booted two times - 3CX Background scrren apper - but the phone could not Register to 3CX Server
    - the Logs files Show on the Server:
    11-Jän-2016 21:52:35.898 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 172.16.57.10:3072 tid=-tmr5laxexv0f Call-ID=313435323435373534333631333036-b1voavcr9hft:
    REGISTER sip:172.16.1.5:5060 SIP/2.0
    Via: SIP/2.0/UDP 172.16.57.10:3072;branch=z9hG4bK-tmr5laxexv0f;rport=3072
    Max-Forwards: 70
    Contact: <sip:10@172.16.57.10:3072;line=yea596dp>;reg-id=1;q=1.0;+sip.instance="<urn:uuid:76ee1144-35f9-4b52-8b4c-000413410873>";mobility="fixed";description="snom870";actor="principal";events="dialog";methods="INVITE,ACK,CANCEL,BYE,REFER,OPTIONS,NOTIFY,SUBSCRIBE,PRACK,MESSAGE,INFO";audio;duplex="full"
    To: "Standger%C3%A4t B%C3%BCro"<sip:10@172.16.1.5:5060>
    From: "Standger%C3%A4t B%C3%BCro"<sip:10@172.16.1.5:5060>;tag=bipr48nvrz
    Call-ID: 313435323435373534333631333036-b1voavcr9hft
    CSeq: 487 REGISTER
    Expires: 120
    Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="414d535c0ca4a71325:281d3bcef0bdf3a3ea06b60fc142c3f6",uri="sip:172.16.1.5:5060",response="9cb6f688a0f80234737a7a55d6c48be7",algorithm=MD5
    Supported: path, gruu
    User-Agent:
    Allow-Events: dialog
    Content-Length: 0
    X-Real-IP: 172.16.57.10
    ; Reason: License limit, processing or network error
    11-Jän-2016 21:52:35.897 Exception: SipMessage::Exception Empty header @ SipMessage.cxx:1296
    11-Jän-2016 21:47:25.835 [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 172.16.57.10:3072 tid=-5fbinvvl5pmk Call-ID=313435323435373534333631333036-b1voavcr9hft:
    Via: SIP/2.0/UDP 172.16.57.10:3072;branch=z9hG4bK-5fbinvvl5pmk;rport=3072
    Max-Forwards: 70
    From: "Standger%C3%A4t B%C3%BCro"<sip:10@172.16.1.5:5060>;tag=g7a8ei9pgo
    CSeq: 485 REGISTER
    Expires: 120
    Proxy-Authorization: Digest username="10",realm="3CXPhoneSystem",nonce="414d535c0ca4a5dd64:1a85dab7a563520de37422ee7e770439",uri="sip:172.16.1.5:5060",response="5246aebbc0d3f49f47cf5b208d8b7f8c",algorithm=MD5
    User-Agent:
    Content-Length: 0
    - on the phone only one entry appear:
    Via: SIP/2.0/UDP 172.16.57.10:3072;branch=z9hG4bK-z9c1jhcf8v0v;rport
    From: "Standger%C3%A4t B%C3%BCro" <sip:10@172.16.1.5:5060>;tag=l1pdxsfkpt
    To: "Standger%C3%A4t B%C3%BCro" <sip:10@172.16.1.5:5060>
    CSeq: 469 REGISTER
    Max-Forwards: 70
    User-Agent:
    Contact: <sip:10@172.16.57.10:3072;line=yea596dp>;reg-id=1;q=1.0;+sip.instance="<urn:uuid:76ee1144-35f9-4b52-8b4c-000413410873>";audio;mobility="fixed";duplex="full";description="snom870";actor="principal";events="dialog";methods="INVITE,ACK,CANCEL,BYE,REFER,OPTIONS,NOTIFY,SUBSCRIBE,PRACK,MESSAGE,INFO"
    Expires: 120
    Content-Length: 0
    how could the SNOM device be different provisioniced from the 3CX Server? I did not know.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,327
    73
    I have seen this before, I am not exactly sure what was causing but it was fixed by:
    1) Resetting the snom phone to Factory Defaults by pressing the # key during boot. If you are using a snom 3xx series check this out: http://wiki.snom.com/FAQ/How_can_I_set_the_phone_back_to_admin_mode_or_factory_defaults_respectively
    2) Reprovision the phone preferably with the uPnP option by highlighting the phone in the "Phones" node in the Management Console, imputing the provisioning link in the Web UI should also work though, if you do this though make sure you use the internal provisioning link.
  3. max999
    Jan 10, 2016
    11
    Hy!
    I resetted the SNOM with pressing "#" - than the 3CX Management Console found the phone - Register - OK!
