Provisioning template editing bug?
Discussion in '3CX Phone System - General' started by pmt, Jan 22, 2013.
  1. pmt
    pmt
    Jan 22, 2013
    8
    Editing of the phone provisioning templates of some phones (ex Yealink T28) is not working. While you can select the phone model from the drop down, the template in the edit window does not update to that model, instead the template viewed previously lingers in the edit window.
    Any suggestions?
  2. lorenzot
    Mar 12, 2013
    I noticed the same issue with the T26. Created a new template renamed, shows in the list but it shows previous. Is this a bug? Trying to test out the template editing.
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    @ALL
    This may help: http://www.3cx.com/blog/advanced-training/provisioning-templates/
