Provisioning template help Yealink T23G
Discussion in '3CX Phone System - General' started by Kevin Burns, Jul 26, 2017.
  1. Kevin Burns
    Apr 3, 2017
    43
    I am trying to add a 3rd account to the provisioning template but cant seem to find where. In the template file there is a lost of account 1 settings but no account 2 settings even though they both get auto-provisioned correctly. I feel like I need to change a 2 to a 3 somewhere, but cannot find out where.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,250
    202
    Why not add the account manually to the phone, via web frontend
  3. Kevin Burns
    Apr 3, 2017
    43
    I am in the process of making changes that will eventually be rolled out to about 50 phones or so. There are a couple other things within the template I have changed, and I am always provisioning new phones for our short term contractors. I'd rather make this template, then for every existing and new phone will have all the same features without having to go back and forth between management console and phone web interface. Its gonna save me a lot of time in the log run.
