Provisioning Template Modifications
Discussion in '3CX Phone System - General' started by ATS-Support, Apr 1, 2013.
  1. ATS-Support
    Jan 16, 2013
    11
    Just curious, wondering whether theres a way of modifying the Grandstream provisioning templates to duplicate the Account 1 extension on subsequent accounts.
    For instance, I want to register extension 100 on multiple line buttons on a GXP-2110, to allow more than 1 call to be answered. I also want to keep the config server path alive to make sure I can keep phones up to date. Problem is, whenever the phone syncs with the PBX, it erases accounts 2-4.
    What I figured, is if account 1 is provisioned using the xml file, if you could modify that xml file to provision the other accounts on a phone.
    Anyone ever tried doing this, or know if it works?
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    You can modify the phone template located at C:\ProgramData\3CX\Data\Http\Templates\phones
    Save the template under a new name then provision your phone using your new template.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Also good video here:
    http://www.3cx.com/blog/advanced-training/provisioning-templates/
  4. ATS-Support
    Jan 16, 2013
    11
    I know I can modify the template, that part is not the issue. By asking to modify the template, I'm implying that I know it can be done.
    What I want to know is what I would have to modify, which fields corresponding with which variables, etc.
    For example, provisioning Account 1 with the extension uses this
    "P270 = %%extension_number%%"
    Is there any sort of knowledgebase that shows what P270 is? would account 2 be P271?
    I doubt just copy/pasting account one below and naming the comments account 2 would do what I want.
  5. netswork
    Mar 11, 2011
    577
    ah. Sorry I am not familiar with grandstream phones or their provisioning but im sure someone here is.
  6. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    7
    See the attached file.
    it has a list of all the P values for GXP phones and a description of what they are used for.
    I'm fairly familiar with the granstream values and what needs to be changed for what. If you have a specific question or need some help with a custom config feel free to PM me.
  7. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    It's not usually possible to provision a phone with more than one extension number. The reason for that, is that an extension profile holds a MAC number that 3CX needs to see as unique for the phone device. There is no mechanism in 3CX to identify an extension profile as being a provisioning target for a phone's 2nd or 3rd line key ...
    I have tried to do this on Yealink's and Cisco phones - but - unfortunately have come to the conclusion that you need to provision your primary extension, then manually input any others you want on second, third etc. line keys on the phones.
    Always hoping to be surprised tho' - so please feel free to astound if you come up with a way of doing this - as I'd love to know ...
    Best regards ...
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,416
    277
    You probably could have a separate provisioning file for the phones that require multiple line precenses... but on Yealink, you only need the account once, then assign the "Line Keys" to the accounts.
    So, I have Account 1 with my extension.
    Then Line Key 1,2,3 are assigned to Account 1
    Can you export your config file from the Grandstream and look at it in text editor to see what changes you mightn eed to make in 3cx Template?
