Provisioning template variables
Discussion in '3CX Phone System - General' started by iwatts, Apr 15, 2011.
  1. iwatts
    Jan 28, 2011
    I thought I posted, but maybe got deleted?
    I am looking for a list of variables used to create provisioning templates.
    Ideally, I would be able to generate a sample provisioning file.. like from the firmware 7.4.8 on an SPA504.. and then replace the field values with the variables 3CX would pass.. but I don't have a "list" to reference.
    While I have working templates and such.. I'd like the ability to review the newer firmware capabilities and leverage any new features where possible.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Why not build your list from the variables used in the existing templates? Also, you can create variables in the Custom Fields and reference them in the templates
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    You can find what your looking for in the SPA documentation from Cisco. If you dont have access to the cisco site you will need to register at least one phone for smartnet.
  4. netswork
    Mar 11, 2011
    577
    --Deleted
