Provisioning Templates
Discussion in '3CX Phone System - General' started by RussRiopelle, Apr 18, 2014.
  1. RussRiopelle
    Feb 4, 2014
    38
    In the 3CX Management Console, under Settings, I do not see Provisioning Templates on the list.
    This is my version of the Management Console:
    3CX Phone System Version 12 Service Pack Update 34902.600.
    Thank You....
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Provisioning templates option is only available on the system that the 3CX PBX software installed through the windows management console.
  3. RussRiopelle
    Feb 4, 2014
    38
    Thank you, did not know that.
