Provisioning used polycom 501
Discussion in '3CX Phone System - General' started by abelaguilar, Dec 8, 2007.
  1. abelaguilar
    Nov 4, 2007
    94
    I have a used polycom 501 that is not loading up its boot server. I would like to use it for 3cx.
    Can someone walk me through the process of adding the necessary software to the polycom 501 so that it boots up and picks up an ip a ddress from 3cx?
    It looks like this phone was used for some ohter pbx system.
    right now, when I turn the power on for the phone it starts booting and finishes with could not contact boot server "error loading 0004f4......cfg" This look like some config file.
    again
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    It should be support following list currently:
    GrandStream GXP-2000
    GrandStream GXP-2020
    Snom 320
    Snom 360
    We using FTP server for all our Polycom Phones ( Over 40pcs) download boot config, bootrom version check and application version check. If get the new version of update. We just in need to put the new version file into our ftp server. Ask users to reboot them will auto download, then update all the things.
  3. abelaguilar
    Nov 4, 2007
    94
    Can you post the files I need to place in the ftp server?
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    The file list FTP server for Polycom phone to access:
    0004f215a48e.cfg
    bootrom.ld
    5QG4-0004f215a48e.cfg
    sip.cfg
    sip.ld
    sip.ver
    0004f215a48e.cfg <------------ This file for individual phone call it's individual phone setting. The file name must use phone's network MAC address
    bootrom.ld <-------------------- Polycom Bootrom (Production use 3.2.3, UAT test use 4.0.0)
    5QG4-0004f215a48e.cfg<----- Individual setting for phone
    sip.cfg<-------------------------- Common setting for Phones
    sip.ld<--------------------------- Polycom Application (Version 2.2.0047)
    sip.ver<------------------------- Polycom Application version file
  5. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I think he's looking for a more complete "how to" guide to provision a polycom phone. I'd like the info myself! :)
    Or if you can just point us to the right spot.
    Thanks.
  6. abelaguilar
    Nov 4, 2007
    94
    Yes a good guide would help.
    i'm assuming, I setup an ftp server with these files in them using my polycom mac address and point the phone to the ip address of the computer acting as the ftp server?
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please email following information for me [5qg4(AT)ccx.ath.cx]
    1. Extension number and extension's password
    2. 3CX BOX IP
    3. FTP server IP
    4. FTP ID and Password for the Phones
    5. Polycom Phone's MAC address
  8. abelaguilar
    Nov 4, 2007
    94
    I would prefer to learn how to do this myself. There's a great learning opportunity for others as well.
    I have setup a ftp server and have placed the ip addres username and password of the ftp server into the polycom.
    rebooted the phone. I can see that the phones gets an ip address from my router and I can see the phone connect to "golden ftp serve pro" software.
    Then something happens and it does not download the files. I have all the necessary files and I have added the mac addess of the phone to the XXXXXXXXXXXX.cfg file.
    anything else i'm supposed to do? sip ip is 2.1.2 and bootrom version is 3.2.3.
  9. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    OK. Please found the steps as below:
    FTP ID must have full access to the ftp root directory. All files put into the root directory of FTP server.
    1. Reset you Polycom phone to factory default. If not works, try format your Polycom. To make sure everything at default.
    2. Config your Polycom point your FTP server with ID which can full access FTP root directory. Once config your Polycom. Don't try to use web admin to change any thing at your Polycom phone. Since the web admin config will override the auto provision config.
    MAC_of_phone.cfg point to the cfg file which contain EXT number, password, digimap and etc of that phone. SIP.cfg which for pointer of SIP server or Proxy to registrar and common settings of those phones.
  10. abelaguilar
    Nov 4, 2007
    94
    wow this is kind of tricky. i'm not sure i understand all of these steps. Mainly towards the end it gets confusing.
    Right now all I have to do is power up my phones and they pick up an ip addres from the router.
    Then I go to a web browser, enter the address and make my configuration changes and it works fine.
    Is there a way to get this phone to work like this?
  11. abelaguilar
    Nov 4, 2007
    94
    i'm testing this at home using a linksys router. can this router prevent the phone from accessing the ftp server on my computer here at home?
  12. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    All works from accidentally formated our first Polycom phone. Since we know that it can download all the things it need from the FTP server then installed back to phone if all files it need at FTP root directory.
    All Polycom Phone after open the box to end users. We never using the web admin at all.
    All following steps are direct using phone menu. (NOT USING WEB ADMIN!!! NO need format and reset factory default or reset local at the phone)
    1. Connect power for your phone (PoE or Power adaptor). Press setup
    2. Keyin 456 then press OK (456 is the default password at phone)
    3. Use cursor down move to DHCP Client then set it ENABLE (The default should be enanle)
    4. Use cursor move to Server Menu then press Select Key (Softkey of phone)
    5. Select server is FTP (If Server type shows FTP then move the cursor down to Server Address)
    6. At Server address press the sofkey "Edit"
    7. Keyin your IP address of FTP server
    8. Keyin FTP ID and Password
    9. Save and EXit
  13. abelaguilar
    Nov 4, 2007
    94
    Yes I have done all of this with no problem. I can even see the polycom access the ftp server but then something happends and it says could not contact boot server "error loading macaddress(polycoms mac address).cfg
  14. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please send me the XXXXXXXXXX.cfg (MAC address of phone) and XXXX-XXXXXXXXXX.cfg to my email account. The FTP server we tested is FileZilla and MS FTP server.
    If you still want to do it yourself. Please check the FTP server root directory. The phone will upload the boot log to it. It should be XXXXXXXXXX.log (XXXXX is MAC address of that phone). Just reminded that if the phone use web admin to modify any config at phone. The phone will boot local config instead of config at FTP server.
  15. abelaguilar
    Nov 4, 2007
    94
    ok let me send these to you.
  16. abelaguilar
    Nov 4, 2007
    94
    what's your email address?
  17. abelaguilar
    Nov 4, 2007
    94
    what is your email address??
  18. abelaguilar
    Nov 4, 2007
    94
    I sent the two files to your address on your web site.
  19. abelaguilar
    Nov 4, 2007
    94
    for ftp server i've been using the trial version of golden ftp server pro 3.66
  20. abelaguilar
    Nov 4, 2007
    94
    ok downloaded and started filezilla server: Here is my log:
    FileZilla Server version 0.9.24 beta
    Copyright 2001-2006 by Tim Kosse (tim.kosse@filezilla-project.org)
    Connecting to server...
    Connected, waiting for authentication
    Logged on
    Retrieving account settings, please wait...
    Done retrieving account settings
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> Connected, sending welcome message...
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 220-FileZilla Server version 0.9.24 beta
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 220 Please visit http://sourceforge.net/projects/filezilla/
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> USER team
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 331 Password required for team
    (000005) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> PASS ****
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 230 Logged on
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> PWD
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 257 "/" is current directory.
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> PASV
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 227 Entering Passive Mode (192,168,0,101,17,96)
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> TYPE I
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 200 Type set to I
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> SIZE bootrom.ld
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 550 File not found
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> RETR bootrom.ld
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> QUIT
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 221 Goodbye
    (000005) 12/9/2007 22:00:43 PM - team (192.168.0.100)> disconnected.
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> Connected, sending welcome message...
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 220-FileZilla Server version 0.9.24 beta
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 220 Please visit http://sourceforge.net/projects/filezilla/
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> USER team
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> 331 Password required for team
    (000006) 12/9/2007 22:00:43 PM - (not logged in) (192.168.0.100)> PASS ****
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 230 Logged on
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> PWD
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 257 "/" is current directory.
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> PASV
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 227 Entering Passive Mode (192,168,0,101,17,97)
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> TYPE I
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 200 Type set to I
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> SIZE 0004f211461d.cfg
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 550 File not found
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> RETR 0004f211461d.cfg
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> CWD /
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 250 CWD successful. "/" is current directory.
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 227 Entering Passive Mode (192,168,0,101,17,98)
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> SIZE 000000000000.cfg
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> RETR 000000000000.cfg
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> QUIT
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> 221 Goodbye
    (000006) 12/9/2007 22:00:43 PM - team (192.168.0.100)> disconnected.
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> Connected, sending welcome message...
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> 220-FileZilla Server version 0.9.24 beta
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> 220 Please visit http://sourceforge.net/projects/filezilla/
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> USER team
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> 331 Password required for team
    (000007) 12/9/2007 22:00:54 PM - (not logged in) (192.168.0.100)> PASS ****
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 230 Logged on
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> PWD
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 257 "/" is current directory.
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> PASV
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 227 Entering Passive Mode (192,168,0,101,17,99)
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> TYPE I
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 200 Type set to I
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> STOR 0004f211461d-boot.log
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 150 Connection accepted
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 226 Transfer OK
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> QUIT
    (000007) 12/9/2007 22:00:54 PM - team (192.168.0.100)> 221 Goodbye
