Provisioning v.15 T27G
Discussion in '3CX Phone System - General' started by infonetics, Jun 2, 2017.
  1. infonetics
    Sep 13, 2011
    41
    I have 2 systems that I'm working with, one provisions fine, the other fails.
    The one that fails, will work if I go into the phone and modify the provisioning link to https://xxx.xxx.xxx.xxx:5001
    Also, I can browse to https://xxx.xxx.xxx.xxx:5001/provisioning...and get the provisioning file to download. if i use http: and 5000, it fails.
    On the server that is working, I can get the file using the http: link.
    On the failing one, I can't login to the admin console using http://5000 either. On the working one, I can (inside LAN)
    I can't find anywhere in the system that is restricting the use of port 5000.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,811
    564
    Hello @infonetics
    Please note that the Nginx web server only accepts http requests from LAN entities. When outside the lan the requests must be in https format or else Nginx will drop them.
  3. infonetics
    Sep 13, 2011
    41
    Yes, this is all from within the LAN.
  4. YiannisH_3CX
    May 10, 2016
    7,811
    564
    Are the phones and the PBX on the same subnet? Is the working system and non working in the same LAN?
  5. infonetics
    Sep 13, 2011
    41
    Yes, phones and PBX are in same subnet. The working/non working system are in different locations and different LAN. They are just 2 identical systems that are behaving differently. Since the provisioining string generated in the extension is http:5000, that is why it fails. I just don't want to have to touch every extension to insert the https:/5001 into the string.
  6. jed
    jed New Member
    Feb 1, 2010
    153
    50
    What is your SUB net?
    Plz. see if your local subnets meet RFC1918. 3CX will see RCF1918 as legal internal IP´s everything else is seen as Remote IP´s.
  7. YiannisH_3CX
    May 10, 2016
    7,811
    564
    Obviously 2 systems installed on different locations and different LAN are not identical. They behave differently because there are differences in the network. When you provision a phone as a local extension then the link will always be http, but if the network is not configured correctly and the requests arrive from a non local IP then this will fail. Check what @jed suggested as it is a common reason for this to happen.
  8. infonetics
    Sep 13, 2011
    41
