Provisioning with google cloud
Discussion in '3CX Phone System - General' started by sitz42, Nov 14, 2016.
  1. sitz42
    Nov 14, 2016
    Hi All,
    I am trying to get my Cisco 525G2 ip phones to auto provision with my 3cx google cloud install. I don't have any kind of BGP setup or anything fancy.. Just a couple phones, callcentric as my provider, and running 3cx on google cloud.
    3CX gives me http://10.138.0.2:5000/provisioning/sum ... vj/$MA.xml as a provisioning link but that doesn't make sense to me and I can't even ping that.)
    When I manually provision, I put in 104.196.231.201:5060 as my proxy and that connects/works fine. I've tried replacing the 10.138.0.2 with the 104.196.231.201 but that doesn't seem to help.
    Thanks so much!
    -Andrew
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
    Hello there,
    It sounds like you are trying to provision the cisco phone as a remote extension in V15. What you are getting from the pbx is the link for local provisioning and not external as cisco SPA's are not supported in v15 as remote extensions (there is no option under phone provisioning tab). Manually it will register but it won't provision.
