Provisioning with Multiple Ports
Discussion in '3CX Phone System - General' started by TheInternship, Dec 11, 2014.
  1. TheInternship
    Nov 20, 2014
    8
    I'm an intern working on my company's phone system. It's on the SPA-525/G2 model and System 12. I've already done a template for most phones but what I was wondering is if someone's IP address has multiple ports(Like they might have a phone for Sales or Support) would provisioning their original phone mess any of that up?
    11,277
    360
    I'm not clear on what you are asking but can hopefully provide an answer that will suffice.
    Sets with the same extension number can exist on different IP's but the extension settings(in 3CX) must allow calls to more than one set at at time...use the busy status of the set rather than the busy status of the extension number (PBX).
    If you are talking about auto provisioning of a set, this usually makes use of the unique MAC address of an individual set using a file that contains that MAC number, so ....one set, one provisioning file.
    There could be other interactions between sets sharing common features, ring groups, call pick-up, etc.. You would have to be a bit more specific in what you are intending to do, and hoping to avoid.
  3. TheInternship
    Nov 20, 2014
    8
    Sorry I'm new at all of this. What I mean is that there are some IP addresses of phones that have multiple ports. So it would be like xxx.xxx.xxx.xx:5060...5061.. and so on. The 5061 port would be for something like Support or Sales that is with another persons phone. If I provisioned the 5060 IP address with my custom template would it affect the other lines?
  4. leejor
    11,277
    360
    If you are editing a template that is used to create provisioning files for more than one set, then you may run into problems. If you are unsure, create a couple of back-ups of the original template (on a USB stick) before you change anything.
    Each of the ports, on one set will be a particular line key. if you are manually modifying the provisioning file for one set, and changing features for one port (extension number on one key), then it should not affect any other set. The provisioning file should contain the MAC for that one set which means that it will not be "picked up" by any other set requesting their provisioning file.
  5. TheInternship
    Nov 20, 2014
    8
    So what you're saying is as long as I am provisioning one phone it shouldn't affect the other ports that are with that line?
  6. jasit
    jasit New Member
    Feb 12, 2013
    173
    check the provision files, because some of them are setup to disable the other accounts on the phone, those lines can be commented out so that they are missing and don't change the settings on the phone,
    jasit
  7. TheInternship
    Nov 20, 2014
    8
    Okay so what I was actually asking was how to provision a phone with a custom template to have multiple extensions. The only way that I have found that to actually work is by adding in Ext_2..3..4 for everything that Ext_1 would have in the provisioning file. It will pull everything but it doesn't get the authentication information for the extension.
  8. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    We use multiple provisioning files and hard code data into the additional accounts where necessary.
    this doesn't help when passwords change - but hopefully you do not have to do that too often. just ensure you use strong passwords from the getco.
  9. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Craig has it right.
    The issue is that provisioning files are based upon the hardware MAC address as this is the only constant. As the MAC is associated to a single extension, it will only pull that extensions credentials. If you were to try and associate the phone, via the provisioning, to another extension, 3CX would give you an warning about the MAC already being assigned to an existing extension. You simply have to code it into the template that is unique for the extension of interest.
    To Jasit's point, you can manually provision the other accounts, but you will need to insure that the templates do not contain info that would overwrite the manual entries to something else.
