Provisioning with v9
Discussion in 'Android' started by KerryG, Jul 23, 2010.
  1. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I see that in the change logs v9 and the latest 3CXPhone say they have support for provisioning but I don't see where to set that up anywhere. Are there any instructions for auto provisioning of the 3CXPhone for Android someplace?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    The V9 PBX supports provisioning for Android phones, but due to some last minute problems with the Android 3CXPhone provisioning it had to be disabled in the 3CXPhone in our internal builds.
    The current released version of the 3CXPhone supports provisioning ( I might be wrong, we may of have replaced it with a Version without Provisioning Enabled ) but it takes a long time to provision. ( This is the issue )
    I'll give you a shout when this is fixed. Though it's gonna take a while
