Provisioning Yealink Phones
Discussion in '3CX Phone System - General' started by green_trek, Aug 10, 2010.
  1. green_trek
    Aug 10, 2010
    6
    I have some T20p Yealink Phones and have managed to provision them correctly. The only thing I cannot work out is where the label field on the phone is set from. I can manually change this via the web interface but when you provision it - it replaced the label with just the extension number. Can this be set when auto-provisioning the phone?
  2. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    You kind of lost me in this post.
    Here is a picture of my Yealink Setup. Which field are you saying keeps getting overwritten when provisioned?
  3. fixit
    Nov 23, 2009
    You can edit the provisioning template for the Yealink T20 within 3CX. Settings - Provisioning Templates
    In the section labled [acccount] - 'Label = %%extension_number%%' by default. I changed the label to be the first name of the user and so had 'Label = %%extension_first_name%%'
    You will need to recreate the extensions afterwards so that the change is written to the extensions .xml file in the provisioning directory. Then just re provision the phones to make the changes.
