Provisioningfile keeps showing old external IP-address
Discussion in 'Windows' started by egimbergh, Aug 26, 2015.
  1. egimbergh
    Aug 20, 2015
    12
    I changed the 'External/Public IP Address' under the 'Phone Provisioning' settings (V12). After that I restarted all the services.
    But still the provisioning-XMLs (under C:\ProgramData\3CX\...\TcxProvFiles) show the old address in the tags
    <MyPhoneServerLocalSSLAddr> and <MyPhoneServerPublicSSLAddr>. The non-SSL tags show the correct values. This happens for current users that I change, but also for newly added users.
    According to Settings - Advanced - Custom parameters the old address is nowhere in the system anymore. I even searched the entire harddisk, but the only occurence of the old address is in two files under C:\Program Files\3CX PhoneSystem\Data\DB\base\16385\, which seem to be databasefiles. I'm a little scared to modify those.
    (Also two occurence in two files under C:\Program Files\3CX PhoneSystem\Data\DB\pg_xlog, but those are just logfiles)
    How do I get the system to completely accept the new address? Note that we run a multi-tennant system, with only a single tennant.
    I already noticed there were more threads about this subject, but I couldn't find a real solution.
    Erik
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi Erik,
    The mentionned fields are related to the SSL configurations done at setup time.
    In order to modify those you will have to :
    - backup all except SSL option
    - uninstall 3cx phone system
    - reinstall 3cx phone system
    - configure the SSL through setup wizard correctly with new valid fqdns/ips
    - restore backup when prompted
  3. egimbergh
    Aug 20, 2015
    12
    Wow, that is not really an easy method for a setting that looks like it's configurable. Sure there's no easier way? Could I try by manually modifying the database files?
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Nope no easier trick as a new SSL certificate needs to be generated, webserver reconfigured, and some other entries needs to be modified, this can only be done once at setup time.
