Proxy Authentication Required/INVITE
Discussion in '3CX Phone System - General' started by kubasz, Jun 12, 2015.
  1. kubasz
    Jul 10, 2011
    I have problem with outbound calls. My voip provider has been registered properly, i can receive inbound calls.
    Trying call I receive error in log:(read from down) I suppose that I should configure outbound parameters specific for my provider. Any advice?
    12-jun-2015 23:26:28.139 [CM503020]: Call(C:13): Normal call termination. Call originator: Extn:101. Reason: Terminated
    12-jun-2015 23:26:28.139 Leg L:13.2[Line:10000>>123456789] is terminated: Cause: 407 Proxy Authentication Required/INVITE from 213.218.116.65:5060
    12-jun-2015 23:26:28.139 L:13.1[Extn] failed to reach Line:10000>>123456789, reason Not Acceptable HereReason Unknown
    12-jun-2015 23:26:28.139 Call to T:Line:10000>>123456789@[Dev:sip:libragp@sip.freeconet.pl:5060] from L:13.1[Extn] failed, cause: Cause: 407 Proxy Authentication Required/INVITE from 213.218.116.65:5060
    12-jun-2015 23:26:28.139 [CM503003]: Call(C:13): Call to <sip:123456789@sip.freeconet.pl:5060> has failed; Cause: 407 Proxy Authentication Required/INVITE from 213.218.116.65:5060
    12-jun-2015 23:26:27.943 [CM503025]: Call(C:13): Calling T:Line:10000>>123456789@[Dev:sip:libragp@sip.freeconet.pl:5060] for L:13.1[Extn]
    12-jun-2015 23:26:27.893 [CM503027]: Call(C:13): From: Extn:101 ("Kasia" <sip:101@192.168.9.200:5060>) to T:Line:10000>>123456789@[Dev:sip:libragp@sip.freeconet.pl:5060]
    12-jun-2015 23:26:27.893 [CM503004]: Call(C:13): Route 1: from L:13.1[Extn] to T:Line:10000>>123456789@[Dev:sip:libragp@sip.freeconet.pl:5060]
    12-jun-2015 23:26:27.893 Line limit check: Current # of calls for line Lc:10000(@FCN[<sip:libragp@sip.freeconet.pl:5060>]) is 0; limit is 2
    12-jun-2015 23:26:27.893 Call(C:13): Call from Extn:101 to 123456789 matches outbound rule 'Outbound to FCN'
    12-jun-2015 23:26:27.892 [CM503001]: Call(C:13): Incoming call from Extn:101 to <sip:123456789@192.168.9.200:5060>
    12-jun-2015 23:26:27.892 NAT/ALG check:L:13.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    12-jun-2015 23:26:10.725 [CM504001]: Endpoint Extn:101: new contact is registered. Contact(s): [sip:101@192.168.9.12:5062 / 101,sip:101@192.168.9.10:56949 / 101]
    12-jun-2015 23:26:05.931 [CM504002]: Endpoint Extn:101: a contact is unregistered. Contact(s): [sip:101@192.168.9.12:5062 / 101]
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Require registration for outbound (and likely inbound..) calls.
