Proxy Manager and V11
Discussion in '3CX Phone System - General' started by ash_mcm, Aug 14, 2012.
  1. ash_mcm
    Aug 14, 2012
    Does the version 11 support the 3CX Proxy Manager?
    In the download list 3CX Proxy Manager does not exist.
    Thank you
    Ash
  2. ash_mcm
    Aug 14, 2012
    Yes, it does support.
    Issue: when I choose from Settings / Network / Local IP the ip of local network then the external extensions cannot reach the 5090 port of the external ip of the 3CX system due the fact that 3cx Tunnel service is listening only on port 5050 of local ip.
    This is the normal behaviour?
  3. StefanW
    Jun 2, 2009
    1,230
    95
    no the tunnel at pbx level listens on 5090 and on the spm site on 5080 for sip
    then the spm connects from a random port to port 5090 of the pbx and proxys the local data for you.
    you may config the tunnel port of the pbx under settings network tunnel
