pstn called projections, failure
Discussion in '3CX Phone System - General' started by pepe75, Sep 25, 2007.
  1. pepe75
    Sep 18, 2007
    Problems with line
    pstn I register ok
    Extensions ok
    Supplier voip ok
    Supplier pstn called inlets ok
    Supplier pstn called projections, failure.
    regards
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    If I understand correctly - all lines register OK, inbound calls on PSTN OK, problem with outbound calls on PSTN. Lots of possibilities. You need to provide information like PSTN Gateway Info, copy of logs, device being used for extension, that sort of stuff..
  3. pepe75
    Sep 18, 2007
    calls of exit in fxo
    Footbridge in use linksys spa 3102 IP 192.168.1.20
    extensions 100-101-102 registered ok
    line 10000 registered ok
    Problem for calls of exit in fxo
    state of the servant 3cx
    10:14: 53,428 CallConf:: Rejected [CM103005] Call (38) is rejected: Not Found
    10:14: 53,428 StratInOut:: onCancel [CM104008] Call (38): Call from Ext.101 to 955999727 terminated; cause: 404 Not Found; from IP: 192.168.1.20
    10:14: 53,147 CallConf:: onIncoming [CM103002] Call (38): Incoming call from 101 (Ext.101) to sip: 955999727@ 192.168.1.10
