PSTN Device -> Dial International number
Discussion in '3CX Phone System - General' started by hanserian, Jan 26, 2012.
  1. hanserian
    Nov 24, 2008
    Dears,
    Am testing the 3CX system am trying to achieve the following any help would be greatful:
    1) Dial In thorugh a PSTN Device
    2) Be prompted with a PIN
    3) Be able to dial an internal Line (i.e. Extension) or different outside lines through a VoIP Provider.
    Please advise if feasible with 3CX and how to achieve it.
    Thanks.
    Jack
    10,740
    281
    Oh, you mean like a DISA port?
    http://3cx.ideascale.com/a/dtd/Real-DISA-trunk-access/71757-9854
    Dial in and back out can be accomplished through your voicemail menu options, at present.
    You can also make use of the security features on a Linksys SPA3102 and dial in through a telephone line on the PSTN port, using Caller ID or PIN screening, that is in turn, registered as a 3CX extension.
