PSTN Error - Incoming Calls
Discussion in '3CX Phone System - General' started by adamtlhern, Aug 5, 2012.
  1. adamtlhern
    Aug 3, 2012
    8
    Hi Everyone,
    I get the following error when i try to call in on one of our PSTN lines.
    15:07:25.578 [CM102001]: Authentication failed for SipReq: INVITE 10001@192.168.123.251 tid=56d0a2609970ae72 cseq=INVITE contact=10002@192.168.123.233:5062 / 21709 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    We have a Grandstream 4104 and have 2 PSTN lines configured and are able to make out going calls but when we make a test incoming call the Grandstream FXO indicator does even light up.
    Any help is appreciated.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Check the setup of the ports and how you have the gxw configured. Normally, the virtual ports would be 10000 & 10001. This shows 10002, but no matter the port and its associated credentials are not liked by 3cx.
  3. adamtlhern
    Aug 3, 2012
    8
    Hi Ineblett,
    The gxw4104 is set up in the following way: Prt 1 = 10001 Prt 2 = 10002 Prt 3 = 10003 Prt 4 = 10004
    3cx will allow me to make calls out.
    But looking at that error I posted, I have just noticed something, well, I think I have. If a call was coming in on 10001 why would 3cx report that 10001 and 10002 have an error when 10002 wasn't in use ??
    The credentials were made up by 3cx and I copied and pasted them across to the gxw management console.
    Should I change them maybe ? Instead of 10001 to 10004 maybe I can change them to 101 to 104 then change the passwords ??
    Also, I have 3cx V10 - Maybe there is a bug I don't know about...?
  4. lneblett
    Sep 7, 2010
    2,061
    56
    Ok then, the ports are set correctly. You just started them 1higher than what I usually see.
    Do all 4 ports show as registered in 3cx? Also, if you go to the status page in the gxw, does this show the ports as registered?
    If any one is not, then try to re-enter the password taking care that no trailing or leading spaces inadvertantly make it into the copy/paste.
    I will need to see the log before I can comment on your concern about how 3cx reported the 10001/02 issue.
    Is this a new implementation of a gxw?
  5. adamtlhern
    Aug 3, 2012
    8
    It is a new implementation of the gxw -
    We only have two PSTN lines so therefore I am only using Port 1 - 10001 and Port 2 - 10002
    In the status page on the gxw the PSTN ports 1 & 2 are "Connected, Idle"
    The two ports in 3cx are registered and working on outgoing calls
    I will switch the gxw off tomorrow & clear the server log, turn it back on and make an outgoing call and also inbound call and send the server log to you if that's ok ?
  6. lneblett
    Sep 7, 2010
    2,061
    56
    Sure, that will be fine.
  7. adamtlhern
    Aug 3, 2012
    8
    OK so this morning I switched the gxw off and cleared the server log then switched it back on. This is what i got ...
    11:02:47.000 [CM102001]: Authentication failed for SipReq: INVITE 10001@192.168.123.251 tid=50a0fcd1fa6388d2 cseq=INVITE contact=10002@192.168.123.233:5062 / 32728 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    11:00:05.125 [CM503008]: Call(22): Call is terminated
    11:00:01.453 [CM503007]: Call(22): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    11:00:01.453 [CM503007]: Call(22): Device joined: sip:105@192.168.123.250:5060
    10:59:56.796 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:59:56.796 [CM503002]: Call(22): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:59:53.453 [CM503025]: Call(22): Calling PSTNline:907535619343@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:59:53.437 [CM503004]: Call(22): Route 2: PSTNline:907535619343@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:59:53.437 [CM503004]: Call(22): Route 1: PSTNline:907535619343@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:59:53.437 [CM503010]: Making route(s) to <sip:9907535619343@192.168.123.251>
    10:59:53.437 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:59:53.421 [CM503001]: Call(22): Incoming call from Ext.105 to <sip:9907535619343@192.168.123.251>
    10:43:32.156 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:43:29.140 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:43:26.062 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:43:23.046 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:43:19.921 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:23:31.046 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:23:28.031 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:23:25.015 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:23:21.953 [CM506004]: STUN request to STUN server 216.93.246.16:3478 has timed out; used Transport: [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:23:18.828 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    10:17:25.750 [CM503008]: Call(21): Call is terminated
    10:17:24.046 Currently active calls - 1: [21]
    10:17:06.390 [CM503007]: Call(21): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    10:17:06.375 [CM503007]: Call(21): Device joined: sip:105@192.168.123.250:5060
    10:17:03.000 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:17:03.000 [CM503002]: Call(21): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:16:59.640 [CM503025]: Call(21): Calling PSTNline:907725946263@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:16:59.609 [CM503004]: Call(21): Route 2: PSTNline:907725946263@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:16:59.609 [CM503004]: Call(21): Route 1: PSTNline:907725946263@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:16:59.593 [CM503010]: Making route(s) to <sip:9907725946263@192.168.123.251>
    10:16:59.593 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:16:59.593 [CM503001]: Call(21): Incoming call from Ext.105 to <sip:9907725946263@192.168.123.251>
    10:15:57.281 [CM503008]: Call(20): Call is terminated
    10:15:48.046 Currently active calls - 1: [20]
    10:15:16.046 Currently active calls - 1: [20]
    10:14:49.625 [CM503007]: Call(20): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    10:14:49.625 [CM503007]: Call(20): Device joined: sip:105@192.168.123.250:5060
    10:14:46.671 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:14:46.671 [CM503002]: Call(20): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:14:44.046 Currently active calls - 1: [20]
    10:14:43.328 [CM503025]: Call(20): Calling PSTNline:907414499141@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:14:43.281 [CM503004]: Call(20): Route 2: PSTNline:907414499141@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:14:43.281 [CM503004]: Call(20): Route 1: PSTNline:907414499141@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:14:43.281 [CM503010]: Making route(s) to <sip:9907414499141@192.168.123.251>
    10:14:43.281 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:14:43.265 [CM503001]: Call(20): Incoming call from Ext.105 to <sip:9907414499141@192.168.123.251>
    10:14:24.562 [CM503008]: Call(19): Call is terminated
    10:14:12.046 Currently active calls - 1: [19]
    10:13:44.265 [CM503007]: Call(19): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    10:13:44.265 [CM503007]: Call(19): Device joined: sip:105@192.168.123.250:5060
    10:13:40.453 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:13:40.453 [CM503002]: Call(19): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:13:40.046 Currently active calls - 1: [19]
    10:13:37.078 [CM503025]: Call(19): Calling PSTNline:907743328450@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:13:37.062 [CM503004]: Call(19): Route 2: PSTNline:907743328450@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:13:37.062 [CM503004]: Call(19): Route 1: PSTNline:907743328450@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:13:37.062 [CM503010]: Making route(s) to <sip:9907743328450@192.168.123.251>
    10:13:37.062 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:13:37.046 [CM503001]: Call(19): Incoming call from Ext.105 to <sip:9907743328450@192.168.123.251>
    10:13:12.562 [CM503008]: Call(18): Call is terminated
    10:13:08.046 Currently active calls - 1: [18]
    10:12:36.046 Currently active calls - 1: [18]
    10:12:18.531 [CM503007]: Call(18): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    10:12:18.515 [CM503007]: Call(18): Device joined: sip:105@192.168.123.250:5060
    10:12:15.781 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:12:15.781 [CM503002]: Call(18): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:12:12.390 [CM503025]: Call(18): Calling PSTNline:907790576196@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:12:12.390 [CM503004]: Call(18): Route 2: PSTNline:907790576196@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:12:12.375 [CM503004]: Call(18): Route 1: PSTNline:907790576196@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:12:12.375 [CM503010]: Making route(s) to <sip:9907790576196@192.168.123.251>
    10:12:12.375 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:12:12.375 [CM503001]: Call(18): Incoming call from Ext.105 to <sip:9907790576196@192.168.123.251>
    10:11:49.828 [CM503008]: Call(17): Call is terminated
    10:11:32.046 Currently active calls - 1: [17]
    10:11:04.093 [CM503007]: Call(17): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    10:11:04.078 [CM503007]: Call(17): Device joined: sip:105@192.168.123.250:5060
    10:11:00.046 Currently active calls - 1: [17]
    10:10:59.578 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:10:59.578 [CM503002]: Call(17): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:10:56.218 [CM503025]: Call(17): Calling PSTNline:907826582569@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:10:56.187 [CM503004]: Call(17): Route 2: PSTNline:907826582569@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:10:56.171 [CM503004]: Call(17): Route 1: PSTNline:907826582569@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:10:56.171 [CM503010]: Making route(s) to <sip:9907826582569@192.168.123.251>
    10:10:56.171 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:10:56.171 [CM503001]: Call(17): Incoming call from Ext.105 to <sip:9907826582569@192.168.123.251>
    10:10:34.421 [CM503008]: Call(16): Call is terminated
    10:10:28.046 Currently active calls - 1: [16]
    10:09:59.468 [CM503007]: Call(16): Device joined: sip:10002@192.168.123.233:5062;transport=udp
    10:09:59.468 [CM503007]: Call(16): Device joined: sip:105@192.168.123.250:5060
    10:09:56.046 Currently active calls - 1: [16]
    10:09:47.671 [CM505002]: Gateway:[Grandstream_GXW4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 2.0, Ch:9) 1.3.4.13] PBX contact: [sip:10002@192.168.123.251:5060]
    10:09:47.671 [CM503002]: Call(16): Alerting sip:10002@192.168.123.233:5062;transport=udp
    10:09:44.312 [CM503025]: Call(16): Calling PSTNline:907799424940@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp]
    10:09:44.265 [CM503004]: Call(16): Route 2: PSTNline:907799424940@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:09:44.265 [CM503004]: Call(16): Route 1: PSTNline:907799424940@(Ln.10002@Grandstream_GXW4104)@[Dev:sip:10002@192.168.123.233:5062;transport=udp,Dev:sip:10001@192.168.123.233:5060;transport=udp]
    10:09:44.265 [CM503010]: Making route(s) to <sip:9907799424940@192.168.123.251>
    10:09:44.265 [CM505001]: Ext.105: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] PBX contact: [sip:105@192.168.123.251:5060]
    10:09:44.250 [CM503001]: Call(16): Incoming call from Ext.105 to <sip:9907799424940@192.168.123.251>
    10:03:17.734 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    09:43:16.625 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server [ V4 199.192.206.228:3478 UDP target domain=unspecified mFlowKey=0 ] over Transport [ V4 192.168.123.251:5060 UDP target domain=unspecified mFlowKey=0 ]
    At 11:00am I made the outbound call
    at 11:02am I made the inbound test call which failed.
  8. lneblett
    Sep 7, 2010
    2,061
    56
    OK, a couple of things -
    Do you have a fixed public IP? If so, then you can turn STUN off, just make sure in the Setting, Network area that you specify what that IP is for both the STUN tab and the Public IP tab.
    It actually looks like you made a call at 10:13 from extension 105 to an outside number. The call ended nearly 40 seconds later. This is call 19.
    this may help pin it down. 99x can be pre-pended to the dial string and this will tell the GXW which port you specifically want the call to go out. The GXW uses a round robin approach (assuming you did not change the settin) in that it autonatically selects the port it wants to use to make the outbound call.
    The way it looks to me at the moment you are using "9" to direct the call to the outside line and then stripping one. I also have the impression that the number 907535619343 is a number for a line that is also associated to the GXW. Is my assumption correct?
    SO, what I would like to try is for you to dial a completely different outside line (not one for the office) and dial it two times, the first using 9991907XXXXXXX and again using 9992907XXXXX (where XXXXXX is the same for both calls) and listen to the handset during the calls. What should happen is that the first 9 should direct the call to the GXW and then the 991 and 992 following should direct the calls out physical ports 1 and 2 respectively. If possible make sure that no other calls are in progress so that we know that a line of interest won't be in use when you try to direct the call to a specific one.
    Also, did you manually provision the GXW or use the template? If you go to the tab (on the left of the 3CX console) and select VoIP PSTN Gateways, how many simultaneous calls does it show? Input 4. Then go to the top where where it indicates Port/Trunk Status and look at each port and under the "other" section on the page, ensure that both in- & out are checked (so that port can both make and receive calls) and finally input 4 for max simulatanteous calls. The max calls may seem confusing, but these are virtual ports and not physical lines, so don't worry about the number. As you only have two lines, you can only physically have 2 calls and the GXW will know that based upon line status.
  9. adamtlhern
    Aug 3, 2012
    8
    This morning after I posted I did a fresh install of the gateway, and I noticed something that I had obviously had been distracted and over looked when I set it up the first time.
    When you set up a PSTN gateway it asks you for the "During Office Time" and "Out of Office Time" extensions I had taken this to be default set at 103 but extension 103 is one of the Linksys phones, and not the group call extension of 100. So the 3cx was sending the request directly to 103 and it was being rejected by the phone.
    I will hold my hand up and say "my bad" but we are working now.
    But upon reading your post yes we do have static IP's so I will turn off the STUN and also look in more detail about the 99 rule.
    Yet again, my friend, I have fixed one problem and come across another... :cry: We all sound like Daleks now and I'm expecting Dr Who to come bursting through the door at any time. Something's wrong with the transmission of the packets, I think its something to do with the RTP Packet Size...It was set to 0.030 and I have set it to 0.020 and we shall see how what goes tomorrow.
    Thanks once again!! :eek:
  10. lneblett
    Sep 7, 2010
    2,061
    56
    Yes, it should be set to .20.
    Glad to see that it is working./
