PSTN incoming and outbound call problems
Discussion in 'Windows' started by iperez_genius, Jul 15, 2008.
  1. iperez_genius
    Jul 1, 2008
    56
    I am still having problems recieving incoming calls through my linksys spa-3000 gateway.
    the pstn line is registered and is idle...ie green light
    i have the identification as the actaul phone number of the pstn line.
    ...So
    I take another normal phone and call the line that is connected to my voip gateway
    Should i expect the digital receptionist to answer the call automatically?
    I am not sure what i need to create or setup inorder to get this working.
    I have a outbound rule setup
    I have a digital receptionist setup 8001
    What am i doing wrong?
    Ilan
  2. iperez_genius
    Jul 1, 2008
    56
    so then this is my problem...
    how do i assign an extension to answer the pstn line?
  3. iperez_genius
    Jul 1, 2008
    56
    okay...
    so that now works...
    this is very exciting..getting closer and closer to a fully working system
    I think i have an issue..which i think others have posted. When the system picks up the call i hear about 1 second of the sound file and then the line goes silient?
    is there a reason for that?
    Ilan
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    No should not be, should work just fine.
    Might be someting in the 3CX settings, with re-registering.
    Gateway capabilities: Set to Re-Invite, deselect Replaces Header
    Locatoin of destination number: select To.User and Request-Line URI leave RemotePartyID empty.
    All other settings are emptly
    Make sure you have your gatewayport set to the same as the PSTN sip port in the SPA.
    For the line ID
    Make sure you selected Allow outbound and Answer incoming calls on this line.
