PSTN/ISDN gateway with 3CX - Australia
Discussion in '3CX Phone System - General' started by pearsondan99, Feb 26, 2008.
  1. pearsondan99
    Nov 4, 2007
    18
    Gday guys,
    Looking for feedback on anyone using a 3CX PABX in australia, particularly in which PSTN/ISDN provider they are using with which VoiP gateway device (in other words what works best)
    Currently on our old system we have four physical lines with a virtual number, so something similar to that would be the go
    Thanks in advance
  2. mandev
    Feb 27, 2008
    35
    My Australian affiliates can probably tell you what you need to know.
    Les.
