PSTN Lines through PAP2?
Discussion in '3CX Phone System - General' started by cs512tr, Jan 2, 2008.
  1. cs512tr
    Jun 20, 2007
    9
    hi all, i have tried the tutorials for other devices but had no luck getting it to work.
    could someone please let me know if the Linksys PAP2 is usable for the "PSTN Line" Functions?
    e.g.
    VoIP Provider is down, can outgoing calls (via outbound rule) be routed through the PSTN Lines, (PAP2 connected to Landline)
    Sincerely
    Carl
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    Yes that is possible and you have to tell the Linksys about that.
    It is called VoIP Fallback to PSTN (Auto PSTN Fallback, generally found under the SIP config on the Lynksys also known as Line 1.
    H.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    PAP2 should be unable to support landline. The 2 FXS ports for analog phones only. The port for support landline should be FXO port.
  4. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    PAP2 is a ATA device it will allow you to connect 2 analogue phone to it. But vice versa is not possible. To connect a PSTN line you need a FXO Gateway.
  5. cs512tr
    Jun 20, 2007
    9
    awesome,
    thanks to everyone for your help!.
    Carl
  6. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Linksys do a SPA 3102 that does FXO for about £50
  7. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    sorry linksys also do a SPA 3000 or sometimes it's called a sipura spa 3000
