PSTN on spa3102 used for fax and voice.
Discussion in '3CX Phone System - General' started by alanweir1, Jun 26, 2009.
  1. alanweir1
    Jun 26, 2009
    Hello All,
    Can the 3CX or SPA3102 tell the difference between a voice or fax call and route it to the appropiate extention.
    Thank you for any help.
    Alan.
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Only if you have more than one number. If you have 2 numbers then you can route them to the correct location based on the number called.
    If you are talking about having a single line with a single number which you want to use for both voice and fax then 3CX cannot discern between the different types.
    The SPA 3102 may be able to discern between the different types but i don't know if it can route to multiple destinations, a read of the manual would hopefully tell you.
