PSTN Unidentified incoming call
Discussion in '3CX Phone System - General' started by baysidesos, Dec 22, 2014.
  1. baysidesos
    Dec 22, 2014
    I am having trouble making inbound calls via my sangoma PSTN
    any help would be appreciated
    [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:33935996@192.168.10.22:5060;transport=udp;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.10.22:5066;rport=5066;branch=z9hG4bK3b258f04-89eb-11e4-b2ae-baf60ad5c1e1
    Max-Forwards: 70
    Contact: <sip:NetborderExpressGateway@192.168.10.22:5066;transport=udp>
    To: "33935996"<sip:33935996@192.168.10.22:5060>
    From: "unknown-caller-name"<sip:unknown-ani@192.168.10.22:5066>;tag=pxip-callid-1419260410-67456-41-127ds-6784-9949d1e0
    Call-ID: 3b24f2c4-89eb-11e4-8ae1-e495fc0b1633@BBG-PBX-022
    CSeq: 15724 INVITE
    Expires: 179
    Allow: INVITE, ACK, BYE, CANCEL, NOTIFY, INFO, OPTIONS, REFER
    Date: Mon, 22 Dec 2014 15:00:13 GMT
    Supported: replaces, 100rel
    User-Agent: Netborder Express Gateway/4.2.2
    Content-Length: 0
    11,086
    325
    I'm seeing only one IP (192.168.10.22) through these logs, with two different ports attached to it. Does it belong to the gateway or the server?
  3. baysidesos
    Dec 22, 2014
    Thanks for your reply.
    That is the IP of our PBX computer
  4. leejor
    11,086
    325
    But...one should be the IP of where the call is coming from...the Gateway. What IP was assigned to it?
