PSTN
Discussion in '3CX Phone System - General' started by ndop, Apr 7, 2008.
  1. ndop
    Mar 28, 2008
    Hallo
    can i use the patton smartnode 4524, 4 port FXO to add PSTN lines to my 3CX PBX
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
  3. carolinainnovative
    May 4, 2009
    369
    6
    Have you tried using one of the other patton templates and modifying it? Like the 4114?
    Also - the 4912 is listed under "vendor supported" in the wiki... see here:
    http://wiki.3cx.com/gateway-configuration/vendor-supported
