Public Holiday IVR
Discussion in 'Ideas' started by Komp, Nov 10, 2016.
Public Holiday IVR 5 5 4votes
5/5, 4 votes
  1. Komp
    Nov 10, 2016
    Create a second option for Public holidays to launch a Digital Receptionist and not just play a message. or allow multiple IVR's against a DID/incoming rule dependent on time or day so different options can be presented to the caller automatically based on the Day and Time they call
  2. alfa4
    Oct 2, 2013
    15
    Isnt this already doable? Since 12.5 even?
  3. Patrick B
    Jan 11, 2017
    For subsideries different holiday plans are very important also more than one option for opening times
