Public ip problem
Discussion in '3CX Phone System - General' started by bela, Feb 18, 2008.
  1. bela
    Oct 17, 2006
    14
    I used the 3.1 with sucesss behind a firewall/NAT, but now I have installed the 5.1 on a dedicated Windows 2003 server sitting in a data center, with a PUBLIC IP.
    No NAT, firewall, anything.
    I have a remote extension at my home sitting behind a NAT firewall.
    Everything appers to be fine, but when a call comes in from lets say broadvoice to an extension, the audio is one way. There is no audio coming from the 3CX to the extension. I have checked this with two VOIP providers, same thing.
    Why is this happening?
    I have tested the same extension with our office PBX (epygi) and it just works fine with that.
    I also tried deleting the STUN setting from 3CX, but then the VOIP provider accounts (broadvoice) wont even register, complaining about STUN errors.
    Why is there no way to turn STUN off in 3CX?
    Bela
  2. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    Just tick the "PBX delivers Audio" under the "other" setting for the Voip Provider settings
  3. bela
    Oct 17, 2006
    14
    This was ticked/checked by default...:(
    Also, I dont get any audio if I call 999 from the extension. The call gets connected, but no audio...
    Looks like the problem is somewhere getting the audio packets from the 3CX to the extension...
    Regards,
    Bela
  4. bluefox8080
    Oct 28, 2007
    181
    Something is definitely blocking your RTP traffic at home...
    Did you do port forwarding on you home gateway for the RTP ports?
    As a test, maybe put your home extension on the DMZ and test again.
  5. bela
    Oct 17, 2006
    14
    Yeah, I have port forwarding enabled, even UPnP.
    The strange part is, that on the same phone I have a second account setup (this is a multi line Linksys SPA-941) which is logged in to our office Epygi PBX, and that seem to work just fine...
    I am really puzzled.
    When I do a firewall test on the 3CX, I get an error 13, as it is on a public IP, and referms to to the FAQ, but there is nothing in the FAQ about this particular situation.
    Bela
  6. bela
    Oct 17, 2006
    14
    Well the new version is pretty useless, will have to downgrade back to 3.1.. :(
    I tried everything, and it looks like the 5.1 does not like to be on a public IP without NAT.
    Bela
  7. bluefox8080
    Oct 28, 2007
    181
    So, version 3.1 actually works and not Version 5.1?
    Tha is very strange...
  8. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please provide "route print" and "ipconfig" output.
    It is really interesting.
  9. martinevans
    Mar 4, 2008
    I have been having a similar problem to you.
    What i have found is that the test simply does not like the fact that you have an external IP
    In relation to audio...
    Ensure that the VOIP provider settings have "PBX" Delivers Audio" is ticked and applied
    Also Ensure that your Extensions DO NOT HAVE "PBX Delivers Audio" Ticket
    Apply it and it should work..
    Kind Regards,
    Martin :p
    (Dublin Ireland)
  10. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    To be really sure that the problem is on 3CX, I would suggest to plug your phone in at the " neighbours" house and see if it' s running there. I did that very easily and came to the conclusion that it was not 3CX but my own internet router/modem which was giving problems. Otherwise you look everywhere but maybe it' s closer to home.
    In case it is in your own home, tell me what router you use.
  11. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I have an SPA 922 at home and I had the same problem you have but with the softphone it was working.
    I try different setting on the spa and at the end it works !!!
    I can make a print of the setting if tou want, I think I had nothing to change on the firwall.
    Next step you will have to solve, I still stuck on that, is to be able to receive a call on the spa 922 at home. I also try to use the 3cx client as a tunnel but no way.
    specialist 3CX please help us, with the softphone 3cx no prob !!!
  12. awcalien8
    Jan 29, 2008
    6
    Is about a port range UDP used.... 9000 or 7000...
    try the linksys default 16384
  13. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    Hello rico06
    could you please post your phone settings?
    best regards
  14. Halea
    Halea New Member
    Jan 5, 2008
    151
    Gents,
    I was going through my notes and I realized that I setup my 3CX computer on the outside of the firewall at one point with a public IP address and no NAT whatsoever, and I can tell you that it worked with an earlier revision of 5.1 (unfortunately I didn't write down the exact version - but I know it wasn't the very last release). During my tests I tried an extension (hard phone) on the LAN and on the WAN with a public IP, and over the WAN behind another router with NAT. They all worked just fine. Are you sure that your main router is not blocking some ports on your network?
    Halea
  15. silentfun
    silentfun Member
    Dec 11, 2006
    364
    if you have a 3cx server in a datacenter and it is possible virtuoso virtual server - have a look at the default gateway it have to be on the same subnetwork to woke fine in my configuration - i have had this problem and the suport personal changed it from diferent subnet to same and it worked.
    andy
  16. Desiderius
    Apr 8, 2008
    @silentfun
    where do i make this options. I have the same problem error (13) and dont find a solution because my english is not the best! Better german :)
  17. andy
    Oct 22, 2007
    23
    I had the same problem with V3.1 and V5. Does your server have multiple IP´s. For example 6 Public IP´s or only 1?
    My server has 5 Public IP´s and I also had a problem with phones behind a NAT device at home.
    I found out the V5 uses the last IP of the 5 public IP´s to establish the connection when calling my phone at home behind NAT.
    But my phone is connected to the first public IP of my server.
    All I did was changing the server that I connect from my phone at home to the last public IP of my server and it works fine.
    Maybe this is also a solution for you.
  18. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    All of our 3cx's are in data centers with public ip.s & each server has
    only one ip. If your box uses more than one ip you will need to use
    that ip in your ip phone or softphone & you can look in the logs to
    see which one you will need to use. This works for V3.1 thru V6 beta.
    We are currently running v5.1.4393.0 & will wait for V6 to come out
    of beta before we upgrade our client systems. 98% of the time when
    there is audio loss problems it is not the 3cx but the consumer router
    that is connected to the ip phones that causes problems. Some ip phones
    have a setting in them Use "RFC3581 Symmetric Routing" yes/no this will
    help you get past the audio problem sometimes. We are using linksys RV08
    RV016 for large clients & a basic linksys router for cable/dsl for small clients.
    With the gradnstream phones we have never setup port forwarding on any of
    the setups using all three routers by linksys. Our basic client setup is as follows.
    1)...linksys RV08 or RV016
    2)...3 to 5 grandstream gxp2010 ip phones
    3)...DL360 G3 server dual xeon 2.8 (data center)
    4)...3 to 8 ext plus 2 to 4 DR
    ecwilson
  19. thomasz
    May 20, 2008
    10
    Maybe the 5.1 has any problem. I think.
