Push notifications not selectable for iPhone
Discussion in '3CX Phone System - General' started by nbrown, May 7, 2014.
  1. nbrown
    May 6, 2014
    22
    I'm trying to trial 3CX but am struggling with activating push notifications for waking up the iPhone. The option just isn't selectable, I can't tick the check box, what am I doing wrong? I've reinstalled three times and even installed a fresh build on a new server (Windows 2008 R2).
    Regards
    Nick
  2. roland_3CX
    roland_3CX New Member
    Mar 28, 2014
    111
    7
    Hello Nbrown,
    If you are using the free version, that feature will not be available ( you will not be able to select it). That feature is available only in the Standard and Pro edition or with a demo key. can you please be a little more specific with as to what version you are using?
  3. nbrown
    May 6, 2014
    22
    Thanks, yes I am using the demo, I registered for the trial but never received any email with the key so couldn't.
  4. nbrown
    May 6, 2014
    22
    I've just registered again and the email has now come through, along with two others from before, thanks for your help.
