Solved Push notifications not working
Discussion in 'iOS' started by robxbl69, Feb 2, 2017.
  1. robxbl69
    Jun 8, 2013
    24
    I've come to realise this week that push notifications are no longer working.
    Myself and 2 other members of staff used 3CX on iOS extensively during the end of 2016 up until 1st week or so December. Last time I remember receiving a call was just after the version with call kit integration was released.
    Since then something has changed or is broken. We've changed nothing (no change in network hardware etc) other than updated 3CX (system), 3CX client and iOS updates as prompted.
    I've needed to use 3CX on iOS this week, but on all occasions push notifications are not working.
    Anyone else have these problems?
    Many thanks.
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi Rob,
    Did you try to resend the welcome email and re-provision using the config file?
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,447
    61
    Mark Anderson likes this.
  4. Paul Omans
    Dec 2, 2016
    83
    28
  5. robxbl69
    Jun 8, 2013
    24
    We're using PRO 15.0.60903.0, so it's not the V14 certificate issue. I'll resend the email and advise later.
  6. Lev
    Lev New Member
    Sep 19, 2015
    117
    15
    We also "still" have problems with push not working with our iPhones.
    We are using 3CX V14, the certificate has been updated on Feb 02.
    Several restarts have been done, no success :-/
  7. Lev
    Lev New Member
    Sep 19, 2015
    117
    15
    Update: Push started working again yesterday.
    I called my hosters support because of it.
    They claym, not to change anything on their side.
    I just did some restarts of all services.
    Then after a while it just started working again.
    It makes me happy, to work again, but it also feels bad, not to really know what the cause was. :-/
  8. Dan McCabe
    Feb 13, 2017
    I am also, still having problems with the PUSH notifications not working. They have been down for weeks now and 3CX is unable to help me. Can someone please help? Here's is what we have tried.
    -Installed IOS Push Update.
    -Uninstalled 3CX and restored with a back up.
    -Uninstalled the IOS app and reinstalled.
    - Sent New registering email. Reregistered phone app.
    - Manually replaced the Push Certificate in the cert folder for Instance1.
    - Restarted server.
    - Triple checked the Ports are all open on the Sonic Wall.
    - Turned off Windows Firewall. (Windows 10)
    Let me know if I'm missing anything. Thanks in advance.
  9. Mark Anderson
    Feb 24, 2017
    6
    We are having this problem. Things were working around the beginning of the year and now they are not. If 3CX is open and has focus on the iPhone then calls will come through. When 3CX is in the background or the phone is locked we don't get anything. We can make calls. This was a really important, transparent feature and now it is unusable. We had the same problem when trying to set up an Android phone, but the Apple phones always worked flawlessly (or as close as you can get to flawless). Also the Android push notification was a lot more complicated to set up.
  10. Dan McCabe
    Feb 13, 2017
    Hey Mark, I ended having to buy a different computer and load the software again from a new install and rebuild the system. They had to transfer the license to the new FDQN. Restoring from an existing backup didn't work for me. 3CX support basically gave the " We don't know answer" Meanwhile, I have 15-20 extension not working for over a month. Good Luck to you.
  11. Mark Anderson
    Feb 24, 2017
    6
    Hi Dan. Thank you for your quick response. I haven't heard anything back from 3CX. I am still trying to figure out where to go for support, our reseller or 3CX. We have the same number of users who were very happy with the iPhone client and now have given up using it. There was a post about an Apple certificate needing to be reinstalled, but the instructions point to a directory that doesn't exist. I am hoping that someone will step up to the plate and fix this. If anything works for us I will let you know.
  12. Patrick Hogan10
    Nov 23, 2016
    27
    Hi Mark. Maybe you should ask your reseller for support as well while waiting for any updates from 3CX.
  13. Mark Anderson
    Feb 24, 2017
    6
    Dan, Again thanks for your earlier response. What worked for us was copying the new Apple security certificate to the directory listed in this post: https://www.3cx.com/blog/news/v14-ios-client-push-certificate/ It would be nice if this were conveyed to us in some way or that our reseller was aware of the problem. If you haven't had any success yet give this a try. We once again have happy iPhone users of 3CX.
  14. Mark Anderson
    Feb 24, 2017
    6
    I didn't mention that they had several week to research this problem while I was on vacation. When back from vacation I sent them an email asking if it might be the Apple certificate and they said "it might be". So I guess that they did help in a way:)
  15. Mark Anderson
    Feb 24, 2017
    6
    Dan, I installed the certificate in the Instance1 folder AND the root folder above that (programdata\3cx\bin\cert\apple).
  16. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Hello @Mark Anderson
    Glad to hear your issue is resolved, would you mind sending me the ticket number in a p.m. so i can have a look at your case?
