Put call On Hold using TCX.PBXAPI.PBXConnection
Discussion in '3CX Phone System - General' started by pclancy, Mar 26, 2009.
  1. pclancy
    Feb 27, 2009
    I'm writing a .NET WCF wrapper around the 3CX API. My problem is that there is no method available to place a call on hold from the PBXConnection object. I can make calls, drop them etc and all works fine. Do I need to transfer the call to a star code or is there another way?
    Any help would be greatly appreciated.
    TIA
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Yes, transfer it to a star code
  3. pclancy
    Feb 27, 2009
    I can't seen a star code for this function, do you know what code to use?
  4. archie
    3CX Support
    Aug 18, 2006
    1,299
    Ah, sorry, I was mistaken, I thought your'e talking about puttnig on parking orbit. No, you can not put anyone on hold. There's no ability in SIP protocol to tell a phone that it is one who puts other side on hold, so we can not implement 3rd party put on hold. To implement it we need standard CTI to all devices. There's no such standard yet, as far as I know.
