Q: Possible to disable the announcement You have a call..?
Discussion in '3CX Phone System - General' started by zorgned, Oct 9, 2013.
  1. zorgned
    Oct 1, 2013
    We are using Phone system 12, SP1 on Windows Server 2012
    Telephones: Grandstream GPX2100
    We are using ringgroups with the option Prioritized hunt.
    I was wondering if it is possible to disable the announcement 'You have a call from 12345' and instead just let the phone ring.
    Thanks in advance
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Re: Q: Possible to disable the announcement You have a call.
    the grandstream talks? i haven't seen this before...
  3. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    6
    Change the ringtone. I know what you are talking about and it is dumb.
    Change the ringtone and that will fix it.
  4. way
    way
    Feb 21, 2011
    49
    3CX is configured to have the phone do this in its provisioning template for External calls. You can change this by going into settings--> provisioning templates --> select the grandstream 2100.
    Look for the 'Distinctive Ring tone' field and change P1489 = 1 to P1489 = 2 or P1489 = 3.
    Reprovision the phones and you should be good to go!
