QoS Handling
Discussion in 'Ideas' started by Brad Allison, Dec 20, 2017.
QoS Handling 5 5 4votes
5/5, 4 votes
  1. Brad Allison
    Jun 7, 2017
    66
    15
    Either through 3CX software or OS policies tag the VoIP traffic for QoS.
    DSCP 46 for RTP
    DSCP 24 for SIP
  2. simply7
    Jan 4, 2016
    38
    17
    I know if you use SNOM phones you can add this config per VLAN QoS settings in the template. What you are talking about is layer 7 based QoS and would depend on the phone to apply this. Personally I do not know of any system that does QoS at layer 7, and just do it at the VLAN level and utilize tagging/trunking for those ports.
  3. Brad Allison
    Jun 7, 2017
    66
    15
    3CX should be setting QoS on phones as part of its templates by default.
    That is not what I'm referring to.
    I'm referring to the OS 3CX is installed on, based off of this
    https://www.3cx.com/blog/voip-howto/qos-windows/
    What I'm asking is that instead of manually doing this to have the 3CX installer create the policies.
    I'm also saying that services should be broken out and the entire OS should not be 56!
    DSCP 46 for RTP
    DSCP 24 for SIP
    "Layer 7 QoS" ? - I don't recall that being part of the OSI model.
  4. simply7
    Jan 4, 2016
    38
    17
    Do you think it that big of a deal since other applications running on the 3CX instance are not supported? I suppose it could be a big deal if you are having the PBX deliver audio, but other than that option, the only thing going on is call setup and tear down.
    Layer 7 I was referring to specific prioritization of a specific application.
    I have found it is easier to just use the Debian install rather than windows.
  5. Brad Allison
    Jun 7, 2017
    66
    15
    Thank you for your comments.
  6. Silly English Kniggit
    Sep 13, 2017
    215
    77
    Agree - 3CX should set QoS across the board, even if some installs the LAN may not support / use QoS. It should also be configured correctly - not just tag all traffic from the server as same DSCP.
