QR provisioning - QR code not displaying
Discussion in '3CX Phone System - General' started by giorgiobusoni, Feb 2, 2018.
  1. giorgiobusoni
    Apr 6, 2011
    32
    If I try to follow the instructions to provision using QR codes, after loggin in the webclient, both going to settings - scan QR code or clicking on the account in the top right corner and clicking on scan QR code will result in no QR code displayed. In the first case, the page is empty below the text inviting me to open the app, in the second a new windows opens up with "scan QR code" but no QR code inside.
  2. giorgiobusoni
    Apr 6, 2011
    32
  3. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
    Hello @giorgiobusoni
    Do you have the same issue with other extensions as well? Or just with this extension?
    Are all other functionalities of the web client working ok?
  4. giorgiobusoni
    Apr 6, 2011
    32
    I have this issue wilth ALL the extensions on that server. We don't really use much the webclinet, but from a quick check other functionalities seem fine
  5. mariosM_3CX
    Nov 1, 2017
    401
    36
    Are you using a supported browser(Chrome, Firefox)? If not, try accessing with a supported browser(updated).
  6. giorgiobusoni
    Apr 6, 2011
    32
    I tried IE, Firefox and Chrome, all updated
    Same browser shows QR code on another 3CX server
  7. mariosM_3CX
    Nov 1, 2017
    401
    36
    Try opening the webclient into an incognito window of the browser and let me know if this fixes the issue
  8. giorgiobusoni
    Apr 6, 2011
    32
    Thnaks for the suggestion, I tried, but it didn't. Same result. It is possible the installation (made by updating through the admin panel) is somehow corrupted? Or some required component missing?
  9. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    Can you disable a few chrome extensions that may be interfering with this? (Ad-block, weird extensions)
    Did you try from another device/pc just to make sure whether it's an issue of the PBX and not your PC?
  10. giorgiobusoni
    Apr 6, 2011
    32
    Yes I tried also another pc with a clean browser (no extensions). Anyway, as I said, another 3CX server works fine with this browser. i really don't see how possibly it could depend on the browser...
  11. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    228
    17
    Can you please tell us if you have updated the system from a previous version? If yes, which one was the version of your first system and what is the exact path you followed for upgrading? e.g. from v 11 to 14 to 15.5
    Also please create a new extension and try provisioning it with the QR code. What is the outcome??
  12. giorgiobusoni
    Apr 6, 2011
    32
    Yes, it was upgraded. I started using 3CX when it was version 9 or 10 I think. It was upgraded all along till 15.5. I don't remember the exact upgrade path. I will now try to create a new dummy extension and check if the QR code shows up. This I haven't tried yet
  13. giorgiobusoni
    Apr 6, 2011
    32
    It works with the new extension! Now it only remains to understand why it is not showing up with the old ones...I would prefer not to delete all extensions and add them back...
  14. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Hi @giorgiobusoni, thank you for coming back
    The reason why the QR code does not appear on your extensions, is because that most probably you did not follow the supported path(as stated in our guides) for upgrading.
    With that being said, i'm afraid that you'll have to delete your existing extensions and create them again if you wish to provision them using the QR code.
    Regards
    #14 IoannisM_3CX, Feb 5, 2018
  15. giorgiobusoni
    Apr 6, 2011
    32
    Well, if it is the only way, I'll do that.
    For minor updates I was always installing them from the management console when I saw them available. For major updates I was making the backup, unistall-install and restore. I'm not sure what step I missed.
    IoannisM_3CX likes this.
  16. IoannisM_3CX
    Aug 10, 2017
    228
    17
    Well..since we don't know exactly what was the upgrading path we cannot know where and how the exactly the issue has occur but what i could tell you is that you must have skipped a major release when upgrading.At least that's what this issue indicates.
    Glad that we found a resolution for this though!
  17. giorgiobusoni
    Apr 6, 2011
    32
    Yes definitely it is possible I skipped one major release (14).
  18. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    733
    112
    @loannism_3cx
    So this is not an acceptable response since 3CX documentation states you can upgrade from v12.5 to V15.5 which skips a major version.
    @giorgiobusoni
    Have you tried just opening the extension and then clicking 'Ok' to 'refresh' it?
  19. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Since the exact upgrade path is not known we do not know which major release was skipped. What @Ioannis_M is suggesting is that this issue has been seen before when the upgrade path was not followed.
