Que Phones do not ring
Discussion in '3CX Phone System - General' started by TCF, Sep 17, 2015.
  1. TCF
    TCF
    May 6, 2015
    92
    I recently installed 3CX V14 while still in our testing phase we noticed that our Customer Service Que Phones no longer ring, the led blinks when a call comes in but the phone nor the headset will ring/give an audible tone. The phone will however ring if I call the extension directly, but all of our 5 phones in Que will not when a call comes into the Que. Any suggestions? I am using Yealink T42G phones
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    845
    125
    Running ver 14, with yealink phones - no issues.
    In the template look for
    distinctive_ring_tones.alert_info.6.ringer =
    Changed the value to 1 to see if this makes any difference
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    380
    50
    Your phone is set to use "silent" for the queue ringtone. You need to adjust this either on the phones or in the template. Some of the older Yealink phones have this issue with the templates.
  4. TCF
    TCF
    May 6, 2015
    92
    Thank you that did the trick! Do you where in the template I can adjust this so I don't have to manually change every phone. I searched through the template for silent.wav but wasn't able to locate the area that needs to be adjusted.
  5. Saqqara
    Mar 12, 2014
    845
    125
    In the template , look for distinctive_ring_tones.alert_info.6.ringer =
    Change the value to 1 or the value you want - 1-Ring1.wav, 2-Ring2.wav, 3-Ring3.wav, 4-Ring4.wav, 5-Ring5.wav, 6-Ring6.wav, 7-Ring7.wav, 8-Ring8.wav.
  6. TCF
    TCF
    May 6, 2015
    92
    Thanks!
