Question about actual Concurrent call # SOLVED
Discussion in '3CX Phone System - General' started by 3397premier, Apr 27, 2012.
  1. 3397premier
    Apr 2, 2012
    43
    Example: Cube A has 20 users, and set to Ring All
    If I use my cell and call to queue A, will it consider 20 active concurrent calls and use 20 Trunks? I think it will only use 1 concurrent call and 1 Sip Trunk, but not sure. Thanks for your help.
    11,105
    329
    Re: Question about actual Concurrent call #
    You mean a ring group/ring all?
    While ringing, it's only considered one call.
  3. 3397premier
    Apr 2, 2012
    43
    Thanks for you quick reply, just want to confirm.
    Example:
    We have 10 trunks
    Queue A has 20 members and set to Ring All
    If a client call in to Queue A, and it rings to 20 members. Does it consider using 20 Trunks and show 20 concurrent call or just only use 1 trunk and show 1 concurrent call?
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    It is one call on one trunk but you will see all 20 phones ring but this will not affect your license.
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Call initiated by internal user (extension, ring sim, rebound) or received from external line uses one quota of license.
    Routing does not "eat" license
  6. 3397premier
    Apr 2, 2012
    43
