Question about disabling GSM on the 3CX softphone
Discussion in '3CX Phone System - General' started by psychobunny83, Dec 12, 2017.
  1. psychobunny83
    Dec 2, 2017
    12
    Under phone provisioning I removed GSM as an option and made G.722 the highest. However in the 3CX softphone if I go to accounts and then advanced, it still shows GSM as first priority and is checked off.
    Does the softphone just respect what I have set in 3CX even though it shows something else? Or should they match?
    Is there a way to see in 3CX what codec is being used?
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    895
    136
    Hi psychobunny83,
    Run a PCAP/Wireshark trace, you can see in the packet what codec is being used.
    You can see the media format in the SIP/SDP information normally.
  3. leejor
    10,361
    226
    If the phone was re-provisioned (and from what you have described, I suspect it has been, then the "old" codecs would be enabled again. You would probably have to edit the configuration template.
