Question about kickback and ivr
Discussion in '3CX Phone System - General' started by jaime6, Feb 28, 2012.
  1. jaime6
    Feb 28, 2012
    5
    Hi all,
    i was browsing through 3cx and i was looking for the kickback configuration and IVR for me to setup.
    I want to use kickback, when the secretary recieves a call and forwards it to the director and he/ she isn't in the office, the call returns to the secretary.
    The IVR I want to use it to redirect incoming calls.
    Also where can I see a report of the calls i made and recieved in 3cx.
    thank you in advance
    10,374
    231
    So what extension forwarding rules, are you using now, to send the call back to the secretary?
    http://www.3cx.com/blog/docs/cdr-call-data-records/
  3. jaime6
    Feb 28, 2012
    5
    Hi, Sorry i'm late, but the setup I have for call forwarding is as follow:
    So rick Ext 100 is the secretary,
    Ext 102 Peter ( director)
    When Rick transfers a call from outside to Peter.
    Ext 102 forwarding rules:
    Available tab:
    No answer:
    Call not answered in 6 sec then:
    Send call to ext 100 Rick
    Phone busy:
    Send call to ext 100 rick
    Away Tab:
    Forward Internal calls to:
    send call to exten 100
    Forward external calls to:
    Send call to exten 100
    This is my fowarding rule, I tried it this way and it seem to work, but not sure if this setup counts as a kickback.
    Also where can I find the Autotendant menu and also the IVR menu
    Thanks in advance
  4. leejor
    10,374
    231
    Hadn't heard it referred to as "kickback" before. You are pretty much limited to the extension forwarding rules available for each extension, which still gives you a lot of flexibility for routing the call.
    The auto attendant and IVR are the same thing, you have to create one (column on the left side).
    http://www.3cx.com/docs/manual/
  5. jaime6
    Feb 28, 2012
    5
    Thank you for the info.
