Question about Ring Groups
Discussion in '3CX Phone System - General' started by kerput, Jul 20, 2010.
  1. kerput
    Jul 20, 2010
    Can the ring group number be a different number of digits than the extensions? I am currently running asterisk and my extensions are 4 digit but my ring groups are 3 digit. This allows my users to dial 3 digits and I can setup custom actions. Can 3cx do the same thing, or does the ring group have to have the same number is digits as my extensions?
  2. carolinainnovative
    May 4, 2009
    369
    6
    Has to maintain the same number of digits.
