Question about the new build
Discussion in '3CX Phone System - General' started by rascott757, Jan 24, 2007.
  1. rascott757
    Jan 13, 2007
    9
    I backed up my configuration and uninstalled the previous build, and then installed the new version.
    What I have noticed is:
    1. The voicemail feature seems to be working better, however:
    a. The system does not seem to recognize extensions longer than 3 digits (I have 4 digit extensions)
    b. I will recheck the manual, but I don't see the option to change the length of the extensions. I wanted to change it back to 3 to see if the voicemail works.
    Thanks very much!
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    The extension length can not be changed after installation. However in the next build we are going to have the extension length configurable during setup.
    Sorry about the inconvenience... We thought most would have 3 digit extensions. It might be better to recreate the configuration if possible...
