Question in regards to Presence Information & 3CXPhone
Discussion in 'Windows' started by Asad1, Mar 23, 2015.
  1. Asad1
    Mar 23, 2015
    Quick question, is it possible to add 3CXPhone as a tab in the Presence Information? Or a way that won't hide the 3CXPhone options behind the Presence Information when I click and view through Active Calls on Presence Information.
    My operating system is windows 7. Version of 3CX is 12.5.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    No it is not possible, you can have the two windows side by side only if presence infos is not full screen.
    Please post this as a feature request on 3CX Ideas : http://www.3cx.com/ideas
