Question in regards to Presence possibilty
Discussion in 'Windows' started by pie4, Mar 26, 2015.
  1. pie4
    Mar 26, 2015
    I would like to know if it's possible to pick up a call witch is intended for somebody else on the presence information ?
    For exemple, someone is calling John but i want to take it before him.
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    If the call is ringing another extension you can pick it up if you use the dial code to pick up a call. By default is *20* provided that the extensions is on the same extension group. Note: One extension can be in more than one extension groups.
    Regards
