Question on call display on polycom 550/650
Discussion in '3CX Phone System - General' started by netswork, Aug 21, 2012.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    On the polycom 550 and 650 phones when your on a call there is a small display bar at the top of the screen. This display bar shows missed calls and some other info and when a second call comes in the caller ID for the second call is displayed in that small window.
    This is unlike the cisco phones where the second call comes into a larger box shown below the current call. Does anyone know if there is a way to change it so that a second incoming call displays in the large section of the screen rather than that small top section of the phone?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Thats not a change I've ever attempted to make however I know you can change the background pics etc..... Though I've never had anyone make that particular request I dont think its possible.
