Question
Discussion in '3CX Phone System - General' started by Hjalmar, Aug 6, 2007.
  1. Hjalmar
    Aug 6, 2007
    5
    first of all, this is a great softwareapplication. Great job!
    I have a question about redirecten, if a customer calls me and i do not answer it will be redirect to my sellphone. But if i don't awnser the sellphone, can i redirect it back to my home phone and back to my sellphone?
    So:
    -> Home phone
    -> Sell phone
    -> again back to home...?
  2. gbarnes
    Aug 3, 2007
    83
    Forward to cell phone
    Yes it does this, I use it.
    Just forward to on Busy etc your mobile number, with a timeout of, say 20 seconds. Then, select on no answer, divert back to digital receptionist, or a voicemail extension.
    Hope this helps.
    Also, when my cell phone is busy, it gives the caller a busy message and goes back to receptionist.
    Graeme.
  3. Ralph
    Ralph Member
    Jun 28, 2007
    417
    Nice trick
    Nice trick gbarnes :wink:
    I am set up so that the caller is given an option to ring the cell phone by pushing a button which then transfers the call to an extension that forwards all calls to a cell number.
    So far I haven't been able to figure out a way to have this option and still have the call returned to the 3CX system if the cell isn't answered.
    Any ideas?? :)
    Take care
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Ralph,
    Yes. 3CX PBX unable to control the cell phone’s fwd feature. However, the cell phone user can be .
    PSTN =>3CX BOX=>EXT A (No Answer FWD Cell Phone)=>CELL Phone [If busy (**67*.....), no answer (**6x*....)and lost connection with provider(**6x*....). Then fwd back to EXT A at 3CX BOX]
    In my region, for my cell phone, I just need to dial **67*PSTN number (EXT A at 3CX BOX). Then if I press end call key when cell phone is ringing, it will divert the call to EXT A at 3CX BOX.
    Regards,
    5Q
