Questions about Virtual Extensions
Discussion in '3CX Phone System - General' started by radujohn, Mar 8, 2007.
  1. radujohn
    Feb 11, 2007
    14
    Hey guys ,
    Any help that I can get for virtual extensions ? I didn't see virtual extensions to your PBX system.
    Respects , RaduJohn
  2. Anonymous
    Anonymous Guest
    OK perhaps you can elaborate on that?
    You can add extensions via the menu on the left. What is what you asking????
  3. radujohn
    Feb 11, 2007
    14
    Let's say that I configure 2 different providers from different countries , and I establish the forwarding with outbound rule to one of those and inbound to the other. Is it going to work like that ? I'm still going to be charged as international call ?
    Respects , RaduJohn
  4. radujohn
    Feb 11, 2007
    14
    ANY helpfull replies ?
    RaduJohn
  5. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    We don't understand what exactly are you trying to do?
    You want to make a call from one country to another thru two VoIP providers and 3CX PBX in-between?
  6. radujohn
    Feb 11, 2007
    14
    Exactly . I want to create a bridge between VOIPs so I would eliminate the international charge. In Asterisk is possible , but I would love to use 3CX.
    RaduJohn
  7. radujohn
    Feb 11, 2007
    14
    No replies .... hmmmmm, Interresting
  8. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Actually you can and it is relativley easy.
    Just set up to 2 Voip Providers (or a VoIP provider and a gateway) and set the incomming line to forward to the 2nd outbound line.
    You might not be able to forward the incoming call directly but you can forward it to an extention that never registers and have that extention set up with a forward all calls rule.
