Questions on BLF Usage and How to Use on hard phone
Discussion in '3CX Phone System - General' started by petewatterschats, Mar 25, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    How do I change status on a hard phone yealink avilble, do not disturb, etc
    How do BLF Type BLF Extension for quick call work on hard phone
    What is the difference between a BLF type and SPEED Dial Type, they seem to be the same
  2. 12494
    12494 Member
    Apr 16, 2010
    280
    20
    You would use the 3CX phone for 'blank' to change the status of the extension. Also you could use a Dial Code from your extension.
    BLFs on a desk phone can be used to dial an extension or transfer a call in progress to the extension.
    BLF can call an extension but it also changes color to show if the extension is engaged in a call. Speed Dial is to dial an extension.
    Allen
