Solved Queue abandoned queue calls
Discussion in '3CX Phone System - General' started by neville, Dec 6, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    226
    42
    I have a question about abandoned queue calls report. Looking at the report, it show queue, call time, waiting time, caller id, agent, polling attempts and agent status.
    I see a call coming in with a waiting time of 2:01 before it was abandoned. 3 agents are logged in and it shows 7 polling attempts for one agent and 0 for the other agents. Needless to say, the caller dropped the call.
    Queue is setup as longest waiting, 15 seconds ring time.
    What exactly is this telling me?
    Is there docs show what these reports are showing. They are very confusing to figure out exactly what is going on.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @neville
    The report is saying that the queue manager polled the same agent 7 times without polling the others. This could happen if the other agents were busy on another call (not necessarily a queue call) that will not show in this report.
    Longest waiting means that for every call that enters the queue, the queue manager will poll the agent that hasn't answered a call the longest first and then move on to the next one after the 15 seconds ring time. If another agent is not available then the same agent will be polled.
  3. neville
    neville New Member
    Apr 23, 2012
    226
    42
    Thank you.
